minifrontpage thumbnail alignment
I'm experiencing a problem with the thumbnail alignment parameter.
They are always aligned to the left regardless of the parameter value.
Apparently in mod_minifrontpage.php there is a check but I noticed that in lastcell.php, lastcolumn.php and bottom.php under themes/tabbed-no-effect/tmpl the class is hardcoded to img-mfp-left.
I tried to change the code forcing mfp-img-right and the thumbnail now are displaying on the right...
I'm wondering if it's a bug?
I'm using version 2.2.0 under joomla 2.5.8
Any idea?
13 years 10 months ago #1 by Gianluca Nigro
I checked the logs and found this error
Undefined property: stdClass::$thumb in /var/www/html/avisastibozza/modules/mod_minifrontpage/themes/tabbed-no-effect/tmpl/bottom.php on line 44
[client 78.134.54.103] PHP Notice: Undefined property: stdClass::$thumb in /var/www/html/avisastibozza/modules/mod_minifrontpage/themes/default/tmpl/bottom.php on line 40
I have two instances of the module on my site... one using default, the other using tabbed-no-effect
I modified the code only fot tabbed-no-effect
13 years 10 months ago #2 by Gianluca Nigro
Hello gian
Thanks a lot for noticing about this thumbnail alignment issue. We have fixed it so you can re-download it.
Regarding the notice $thumb on line 40 and 44 on those files on your last post that's a different stories so we need more infos from you. Do you have thumbnail images on the module shows up as aresult of your inserted article images inside the Editor?
Let us know then
13 years 10 months ago #3 by erwinschro
thank you for your prompt reply... I'm going to reinstall the module and check
About the error... the answer is yes, I have some articles where the thumbnail is coming from the article body
13 years 10 months ago #4 by Gianluca Nigro
