minifrontpage
is there a possibility to ad a default thumb to minifp in case there is an article without picture?
Now its generating an error if i place an article without picture.
10 years 10 months ago #1 by Thei
Hi, Can you tell me what is the error message? Anyway, try to go to your administrator page then open System -> Global Configuration -> Server and set the Error Reporting to None
10 years 10 months ago #2 by TemplatePlazza
Error message is:
Notice: Undefined property: stdClass::$thumb in /public/sites/scopias.mediacradle.nl/modules/mod_minifrontpage/themes/tabbed-slide-left-right/tmpl/bottom.php on line 48
It diassapears when i set error reporting to none or sipmle.
But it would be really great if i could insert a default image.
Thanks for your help.
10 years 10 months ago #3 by Thei
Hi you can do that by editing the file root/modules/mod_minifrontpage/mod_minifrontpage.php:
at line 105 you will see this code :
foreach($list as $index => $item)
	if ($thumb_embed)
change that to
{$item->thumb = "<img src='path/to/your/default/image' />";
	if ($thumb_embed)
10 years 10 months ago #4 by TemplatePlazza
Thank for this very fast answer.
Insertion of the above code is working.
But now the allignement of the text is below the article and not on the side.
You can check it on my testsite scopias.mediacradle.nl
The articles with the scopias logo.
10 years 10 months ago #5 by Thei
Hi, try to change the code I suggested before to this one :
{$item->thumb = "<img src='path/to/your/default/image' class='mfp-img-left'/>";
    if ($thumb_embed)
10 years 10 months ago #6 by TemplatePlazza
