I get > display every after i use xtypo
- Posted by Exnet Hellas (3) Offline
Every after I use xtypo I get this > letter.
joxi.ru/ZrJYKV3u1MZRXA
I checked my code and there is nothing like this 'left' alone, so there is no reason I get this on display.
Do you know why is that happening?
Thanks in advance!
10 years 10 months ago #1
by Exnet Hellas
Thanks in advance!
Hi, Can you let me know the URL of your site so I can take a look?
10 years 10 months ago #2
Hi there,
this is the link and you should login to see the article
company.exnet.gr/index.php/el/odigos-kataxorisis-2/efarmogi-2
username: templateplazza
pass: templateplazza
Thanks in advance
10 years 10 months ago #3
by Exnet Hellas
Thanks in advance
Hi, it's really strange when I see the html source there's a '>' code inserted there? How did you add the xtypo tag? Did you use xtypo button or manually typing the tag? (eg. {xtypo_tag...})
Is it possible for you to provide temporary access to your administrator page so I can check it by myself? If it's possible you can enter the details using the "You Site Details" tab below. Only support team who are able to see that.
10 years 9 months ago #4
I found my problem. I should have set read more. Now that I have set read more, it is working fine!
Thanks for the respond!
10 years 9 months ago #5
by Exnet Hellas
