Pagepeel
have with Pagepeel problems
if I choose no module position, it does not appear
it appears when I selected module position
but when smartphones ed key is positioned centrally
Choose Layout Type change bring no solution
10 years 5 months ago #1 by haci murat
  • Posted by TemplatePlazza (5456) Offline
Hi yes, because it's a module then it need to be placed under a module position. Can you share your website url so I can have a look on it?
10 years 5 months ago #2 by TemplatePlazza
Here
www.bsamanci.com/
Modulposition is Right
10 years 5 months ago #3 by haci murat
Hi, I have visited your website, and everything looks fine. Can you explain the issue in a bit more detail?
10 years 5 months ago #4 by TemplatePlazza
my Problem is Smartphone view
(iPad/iPhone)
www.bilder-upload.eu/show.php?file=16a440-1456300872.png
10 years 5 months ago #5 by haci murat
Hmm, can you try to add this code to your css file and let me know the result :
#page-peel-banner {
text-align:right!important;
float:right!important;
right:0!important;
position:absolute!important;}
10 years 5 months ago #6 by TemplatePlazza
