Menu2Panel
Is it possible to make a "parent" menu item (i.e. the top level menu item under which any sub menu items sit) not link to an article but automatically 'slide' the to the 2nd level of navigation?
I can achieve the desired effect by making the parent menu item a "text separator" but that messes up my menu on the desktop version
Is there a segment of code I can adjust to create the desired effect?
Many thanks
10 years 7 months ago #1 by Ant
Hi could you tell me what type of layout you use? Is it the default one or DL menu
10 years 7 months ago #2 by TemplatePlazza
Thanks for getting back, it's the default version I'm using.
10 years 7 months ago #3 by Ant
Is there a segment of code I can edit in mod_menu2panel > tmpl > default.php?
10 years 7 months ago #4 by Ant
How about to just hiding the separator menu on the destop display using css?
li.divider {
display:none;}
@media max-width: 480px {
li.divider {
display:block;}
10 years 7 months ago #5 by TemplatePlazza
When make the "menu item type" is set as a text separator the parent menu link already disappears from the desktop menu?
Ideally what I would like to achieve is that when the viewing the mobile version (and using the menu2panel menu) that the parent link uses the href="#menu-s0" (as it would if the menu item type were a text separator) rather than href="article-title-goes-here"
Is there a way of adjusting the menu2panel code so that parent items only use href="#menu-s0"
10 years 7 months ago #6 by Ant
