XTypo compatibility with PHP 7.0
I just wanted to ask if XTypo is compatible with PHP 7.0. Has it been tested?
Thank you for confirming,
George
10 years 7 months ago #1 by George P
Hi, I haven't been able to install joomla 3.5 with php 7 in my local environtment yet. If you could, please try yourself and let us know if there's any issue with that.
10 years 7 months ago #2 by TemplatePlazza
I am running my website under PHP 7. I have an error with Xtyp.
I have attached a screen copy of the problem.
I hope you will find a solution because your plugin is very useful.
10 years 2 months ago #3 by Amar Guillen
Hi, can you try to open the file ../plugins/content/xtypo/xtypo.php
at lines you will see this code :
function plgContentxtypo(&$subject, $params){
could you try to change that to :
function __construct(&$subject, $params){
and let me know the result
10 years 2 months ago #4 by TemplatePlazza
thank you for your reply.
It works perfectly. Thank you very much.
You can close the case.
Have a nice day.
10 years 2 months ago #5 by Amar Guillen
I have also been using it with Joomla 3.6.2 and PHP 7.0.10 without issues. I haven't come across the above notice when i enabled the error reporting (otherwise i would have reported it), but it would be great if the fix is provided as an update together with any other PHP 7 code updates that might be needed!
Thank you for the great extension :)
10 years 2 months ago #6 by George P
