Layout Question
- Posted by John Cawood (4) Offline
How do I remove the captions on the Responsive Banner slider? and How do I centre the module? please help.. looks terrible on the left hand side? www.meditrader.co.za/services/practice-profiling
10 years 6 months ago #1
by John Cawood
Hi, I'm not familiar with your template but I think it because you have placed the module in the area that have only 25% width, because the module will adapt to its wrapper width.
Please see this www.dropbox.com/s/gmfsfz9wci7khqv/rbsss1.mp4?raw=1
10 years 6 months ago #2
Thank you admin.. I used advanced tab in module parameters to adjust the boostrap width... when I first installed it was full width but its too wide... problem is the template... damn.. ok I will try mess with the template css/div... thank you.. how can I take off the caption overlay for that style though.. its not needed
10 years 6 months ago #3
by John Cawood
Ah ok.
or alternatively use the different effect (nivo)
10 years 6 months ago #4
Did you mean the animated text with the black background? If so, you can add this code to your csshow can I take off the caption overlay for that style though.. its not needed
.seqtitle,.subseqtitle{
display:none!important;}Please Log in or Create an account to join the conversation.
Hi there.. OK I used an alternative.. got the layout perfect with my static ads.. but now the module is INTERMITTENTLY repeating itself underneath.. when you put your mouse over the banners and move it.. the banners stack.. its not good...
check it here: www.meditrader.co.za/services/practice-profiling
10 years 6 months ago #5
by John Cawood
hi, can you temporarily switch the template to protostar to see whether this issue related to template or something else?
10 years 6 months ago #6
