All options for JBounce
Hi there, I assume JBounce is based on Ouibounce - github.com/carlsednaoui/ouibounce#sensitivity\n\nIf so, I'd really like to see the other options in the back end, the aggressive mode, the sensitivity etc. I assume aggressive mode is development mode. For development mode I'd really like it if the options were not just yes/no but yes/no/super admin.\n\nAlso it would be good if we could have it trigger only a set amount of times per user session. I.e. if the person simply clicks to navigate to another page then it shouldn't trigger over and over again as that is a little annoying.
10 years 5 months ago #1 by Eoin Feeney
Hi, Agressive mode is Development mode in the module backend. I'm not really sure other features you're suggested are really necessary but basically you can modify the file modules/mod_jbounce/tmpl/default.php for that.
10 years 4 months ago #2 by TemplatePlazza
