Module in Modal - RS Forms conflict
I like to use the Module in Modal extension with RS Forms. I loaded both extensions with {loadposition} into a article. As soon I have RS Forms module loaded the Module in Modal does not work anymore.
This is the affected area:
scoomadesign.com
Also the documentation is very limited so i like to know if i can use this Module in Modal module multiple times with different contents on one website.
Thanks you!
10 years 3 months ago #1 by Mathias
Hi, I see on the page you're referred that your website loaded multiple jquery libs. One is loaded at line 44 (before the module code) and the other one is at line 449 (that probably causes the issue). I'd suggest you to install jquery easy to fix jquery confliction issue
10 years 3 months ago #2 by TemplatePlazza
Works perfect! Thanks for the fast support!
10 years 3 months ago #3 by Mathias
No problem at all glad I could help
10 years 3 months ago #4 by TemplatePlazza
