Categories not selected are shown
Hello good people!
First of all thank you for making this great extension free! I really enjoy it.
I'm sorry if I do some mistakes, English isn't my native language.
When I select some child-categories they show another categories also!
Mi categories are
Obras Sociales (1 Active / 0 Trashed) default Public All 1
. |_ Normativas (4 Active / 0 Trashed) default Public All 7
. |_ Normativas Especiales (3 Active / 0 Trashed) default Public All 8
. |_ Carátulas (1 Active / 0 Trashed) default Public All 9
Presidencia (3 Active / 0 Trashed) default Public All 2
Informacion General (1 Active / 0 Trashed) default Public All 3
Asuntos Profesionales (0 Active / 0 Trashed) default Public All 4
. |_ Informativo ANMAT (0 Active / 0 Trashed) default Public All 10
. |_ Residuos Patógenos (0 Active / 0 Trashed) default Public All 11
. |_ Inspeción de Farmacias (1 Active / 0 Trashed) default Public All 12
. |_ Seguro Mala Praxis (0 Active / 0 Trashed) default Public All 13
Capacitaciones y Eventos (4 Active / 0 Trashed) default Public All 5
Descargas (0 Active / 0 Trashed) default Public All 6
. |_ Vademecum (1 Active / 0 Trashed) default Public All 14
. |_ Carátulas (0 Active / 0 Trashed) default Public All 15
. |_ Padrones (1 Active / 0 Trashed) default Public All 16
. |_ Formularios (0 Active / 0 Trashed)
A setting
Source Retrieve items from categories
Another setting
Filter Category all (off) / select (on)
The selected Categories are
Obras Sociales (parent category)
Normativa (child category)
Normativas Especiales(child category)
Carátulas (child category)
And the front-end is
Filtered by All Carátulas Normativas Especiales Normativas Presidencia Capacitaciones y Eventos
And I don't know why "Presidencia" and "capacitaciones" are shown.
I do a copy-paste of the PORTFOLIO subtemplate, and call it MINIMALIST. The ONLY change that I did was in the default.php -> FOLIO CONTAINER. But i didn't touch the
"div id=filter"
Anyway the problem was before the new subtemplate.
So maybe is a JS problem? Or the others minik2 in the home?
In the site details I leave a user and a pass.
All the categories was created via k2.
Cheers and I will waiting for your help.
10 years 3 months ago #1 by Cristian
Hi, Can you try to publish only one minik2 module and see whether the issue persists or not?
10 years 3 months ago #2 by TemplatePlazza
Yes!! I delete (sent to the paper bin) the other modules, and it show the right items in the filter.
I think the problem was because I copy-paste the module and use the same filter, but when I create a new Mini k2 Module the error occurs again.
Should I modify the script.js? ( modules\mod_minik2\tmpl\TEMPLATENAME\assets\script.js )
Creating a FOR loop or something, modificating the word "FILTER" to "FILTER[0]" from the 53 line to the final?
10 years 3 months ago #3 by Cristian
Hi, yes it's probably because of js conflict. Try to rename all classes name in the default file . For example
<div id="filter"></div>
<div id="folio-container">
    <ul id="stage">
to
<div id="filter2"></div>
<div id="folio-container2">
    <ul id="stage2">
then change all the class names in the script.js as well
10 years 3 months ago #4 by TemplatePlazza
Thanks for your answer, I modify the default.php and the script.js and the issue continues.
The script.js with the modification is
jQuery.noConflict();
jQuery(document).ready(function(){
	var items = jQuery('#stage2 li'),
		itemsByTags = {};
	// Looping though all the li items:
	items.each(function(i){
		var elem = jQuery(this),
			tags = elem.data('type').split(',');
		// Adding a data-id attribute. Required by the Quicksand plugin:
		elem.attr('data-id',i);
		jQuery.each(tags,function(key,value){
			// Removing extra whitespace:
			value = jQuery.trim(value);
			if(!(value in itemsByTags)){
				// Create an empty array to hold this item:
				itemsByTags[value] = [];
			// Each item is added to one array per tag:
			itemsByTags[value].push(elem);
	// Creating the "Everything" option in the menu:
    var filtertext = jQuery('<span>'+WORD_FILTER_BY+'</span>').appendTo('#filter2');
	createList(WORD_EVERYTHING,items);
	// Looping though the arrays in itemsByTags:
	jQuery.each(itemsByTags,function(k,v){
		createList(k,v);
	jQuery('#filter2 a').live('click',function(e){
		var link = jQuery(this);
		link.addClass('active').siblings().removeClass('active');
		// Using the Quicksand plugin to animate the li items.
		// It uses data('list') defined by our createList function:
		jQuery('#stage2').quicksand(link.data('list').find('li'));
		e.preventDefault();
	jQuery('#filter a:first').click();
	function createList(text,items){
		// This is a helper function that takes the
		// text of a menu button and array of li items
		// Creating an empty unordered list:
		var ul = jQuery('<ul>',{'class':'hidden'});
		jQuery.each(items,function(){
			// Creating a copy of each li item
			// and adding it to the list:
			jQuery(this).clone().appendTo(ul);
		ul.appendTo('#portfolio-container2');
		// Creating a menu item. The unordered list is added
		// as a data parameter (available via .data('list'):
		var a = jQuery('<a>',{
			html: text,
			href:'#',
			data: {list:ul}
		}).appendTo('#filter2');
I think I modified right.
10 years 3 months ago #5 by Cristian
at lines 53 is not changed yet to #filter2
10 years 3 months ago #6 by TemplatePlazza
