Deal Plazza tempalte problem
- Posted by rottenberg (60) Offline
hello
I have a problem with Deal Plazza template when the page is just a little bit higher than computer screen height.
my screen is 1680x1050. When I am on a page which is a little bit higher (I cannot give you the size exactly) I can't get the page footer on my screen.
I see te screen displaying the footer and immediatly doming back to the head. I don't get the sticky logo bar.
If the page is higher than the critical size ( can't give you the exact size) no problem te sticky logo bar size is activated.
I have added an example in the attached reference ilink (to get the problem dis it on a 1680x1050 screen.
the template version is the 1.0.2
thank you for help
best regards
Michel
13 years 10 months ago #1
by rottenberg
thank you for help
best regards
Michel
Hello rottergberg,
Can you please try to add this css code to this file : [root]/templates/deals_plazza/css/template.css
13 years 10 months ago #2
#row7 {min-height: 1050px!important;}Please Log in or Create an account to join the conversation.
hello
sorry I have put resolved but it's not.
nothing has change
I join the cs file to check
thank you
best regards
Michel
13 years 10 months ago #3
by rottenberg
nothing has change
thank you
best regards
Michel
Sorry once more
I have cleaned the cache it's working now
thank you
Michel
13 years 10 months ago #4
by rottenberg
thank you
Michel
- Posted by ronysyz (191) Offline
Thanks for your confirmation and we are happy with your success
13 years 10 months ago #5
by ronysyz
