Xtypo in Custom HTML module
- Posted by Cobb (2) Offline
When using Xtypo in articles it is working fine. However, when using Xtypo in a Custom HTML module it doesn't. How come, and is there a way around it?
Kr/Cobb
13 years 10 months ago #1
by Cobb
Kr/Cobb
- Posted by ronysyz (191) Offline
Thanks for your confirmation
after i tried to check it since several hours ago, when we are using in a Custom HTML module, we must add the xtypo codes manually with using "HTML Source Editor".
for example:
or you can use XTypo button to add it
13 years 10 months ago #2
by ronysyz
for example:
<p class="xtypo_alert">TEST</p>
<p class="xtypo_info">TEST</p>
<p class="xtypo_warning">TEST</p>
<p class="xtypo_sticky">TEST</p>
<p class="xtypo_feed">TEST</p>
<p class="xtypo_download">TEST</p>or you can use XTypo button to add it
Hi Ronysyz,
first of all thanks for your reply.
The above aproach is partly working. Of the lines given above only xtypo_alert doesn't work, the others do. However, when used they fill the entire width of the page. Furthermore, just like alert doesn't seem the work, neither does xtypo_list. I haven't gone as far as to try all of the tags. But for now my guess is that not all tags can be used in the class approach. Nevertheless, great answer, when I figure out more I will post it here...
Like:
<p>{xtypo_quote}Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat {/xtypo_quote}</p>
seems to work as well in a custom HTML, provided you use the HTML editor...
13 years 10 months ago #3
by Cobb
Like:
