mini K2 newsticker
- Posted by Jörg Michael Günther (4) Offline
I´ve just downloaded and installed the mini K2 module.
I need a newsticker vor My side www.schwedentraum.se
If try´d other then newsticker some works well but the newsticker shows no contend
Can you help me ? I´m using Joomla 3.6.2 and K2 allthought downloaded and installed just some days ago, so it´s the newest version, thought.
WBR
Jörg
10 years 2 months ago #1
WBR
Jörg
Hi, it looks like because your website loads multiple jquery lib. Please try to install jquery easy plugin solve jquery lib confliction issue
10 years 2 months ago #2
Hej
Thanks for the fast response
jquery-easy is installed
The other parts of mii K2 are working but not the ticker
WBR
Jörg
10 years 2 months ago #3
WBR
Jörg
From what I see, your website still loads multiple jquery. One from here :
www.schwedentraum.se/media/jui/js/jquery.min.js and the other one from here ajax.googleapis.com/ajax/libs/jquery/1.8.3/jquery.min.js
Are you sure the jquery easy is installed properly?
10 years 2 months ago #4
Thanks. It works now. But it seem that the row is to little in the high
WBR
Jörg
10 years 2 months ago #5
WBR
Jörg
Have found opitions
Thanks so much for help
Have a nice day
WBR
Jörg
10 years 2 months ago #6
Have a nice day
WBR
Jörg
