Module in Modal not displaying
Dear TemplatePlazza Developers and Community,
I purchased Module in Modal, but no matter what I try, it won't display.
I tried "content source" html content and module position.
I tried publishing in numerous different positions.
I tried publishing on all pages and specific pages.
etc...
Although I'll likely have other uses for this extension later, currently I'm just trying to get a modal to appear in bottom center like the one in the demo @ demo.templateplazza.com/joomla/index.php/bottom-center
Here are my module settings: imgur.com/vW6qgMH
Thank you,
Oman
10 years 2 months ago #1 by s
Hi, can you switch the template into default one (protostar) to see whether this is related to template problem or something else
10 years 2 months ago #2 by TemplatePlazza
Unfortunately, no.
In order to help with speed issues, extra templates etc have been eliminated/deleted.
10 years 2 months ago #3 by s
I think this is not true. I believe leaving default template on your joomla won't affect your website performance because joomla won't access inactive template files.
10 years 2 months ago #4 by TemplatePlazza
At any rate, Protostar has been removed from our site and is no longer accessible.
10 years 2 months ago #5 by s
Ah, I just found the probelm.
The problem is because you have published the module in the offcanvas position that is not exist / visible on your template. I have changed the position to user21 and looks like it's working fine now. please check
10 years 2 months ago #6 by TemplatePlazza
