Responsive Banner Slider module overrides other content
- Posted by Ary Tolentino (4) Offline
I bought Responsive Banner Slider module and after installing it overrides the various modules of k2 that I use on the site . Sometimes the module operates normally but sometimes get error.
Due to the error I disabled the module on the main page , but you can check the error in the other pages likes regional, nacional , etc.
I need help to solve the problem .
10 years 2 months ago #1
by Ary Tolentino
Hi, I think this is because you banners have different height. Can you try to make them all to have identical width and height?
10 years 2 months ago #2
I think this is not the problem. I am using two banner with the same size , but still from time to time the module overrides the modules k2 .
10 years 2 months ago #3
by Ary Tolentino
Hi, I've tried to enable the module on the home page and I'm unable spot the K2 issues you've mentioned before. The slide is working properly except the no animation issue at the first load (I think this is related to lazy load image plugin you have installed on your website)
Could you me more detail about the k2 issue?
10 years 2 months ago #4
i've disabled lazy load to test the module but still overlap the modules k2 . Sometimes the banner appears correctly , but when loading the page I see two banners before starting the animation.
It may be some incompatibility with k2 modules ?
10 years 2 months ago #5
by Ary Tolentino
Hi, I've made some tests on your website but unfortunately I still have no solution for that. I found the problem is because the adaptor javascript is mistakenly calculate the height of slider wrapper. This looks like because of javascript confliction with other javascript you have, but I can't check them all because you have so many javascripts on your website and I'm not really familiar with your template structure.
Really sorry about that.
10 years 2 months ago #6
