Because the items and image are not seen in a mini module frontpage duplicate?
- Posted by cubas jara (4) Offline
Hi. Why not query the items and image are in a mini module frontpage duplicate?
I've changed the category of items in the mini module frontpage and are not to be published, please help. Thank you.
Hola. Una consulta ¿Porque no se ven los articulos e imagen en un modulo mini frontpage duplicado?
Le he cambiado la categoría de artículos en el modulo mini frontpage y no se ven al ser publicados, por favor ayudeme. Gracias.
10 years 2 months ago #1
by cubas jara
Hi, Are you sure both of content category contains published articles?
10 years 2 months ago #2
Thanks, I corrected, the items was not seen because the category did not. Sorry to bother you.
Now the problem is that do not display images MINI FRONTPAGE module.
10 years 1 month ago #3
by cubas jara
Hi, I see on your website valicha.com/web/index.php/politica-y-opinion only 2015 tab that doesn't show the article's thumbnail correctly. Can you check what is the differences you have on minifp published on this tab compared to other tabs?
10 years 1 month ago #4
Hi. A to be that in certain articles images are not seen on the MINI FRONTPAGE? Note the inset image is correct.
Please check the Policy tab 2015. Thanks.
10 years 1 month ago #5
by cubas jara
