Related Items Extended problem with menu tablet
- Posted by Theo Tromp (3) Offline
I have installed Related Items Extended and this work good on a desktop/laptop. But give a problem with a smartphone that have I solved with block from the smartphone. But if he is active have a on my tablet NO menu more. If a make the module noactive have I a good menu.
How can I this solved?
10 years 1 month ago #1
by Theo Tromp
Hi, I try to reach your website but it turns error message :
10 years 1 month ago #2
This site can’t be reached
tt.tt-wandel**izen.nl’s server DNS address could not be found.
Ah ok. looks like you have entered the wrong url in the site details above. ok, now I'm able to access the website.It is www.tt-wandelreizen.nl not tt.tt-wandelreizen
Anyway, I'm unable to spot the module published in your website. Could you point me to the page where the module is published?
Hi theo, it looks like your template hides that block/module poisition where the module published, for the phone/tablet view. Can you try to publish the module in other position to check whether the problem persist or not?
10 years 1 month ago #6
