Deals Plazza issue after joomla install
Just installed my deals plazza and it has no images and the code is completely ruined. The site is full of links versus looking like the demo site.
2013.inhousegfx.com/deals
13 years 9 months ago #1 by tony Smith
Can you please check if the following file is writeable or not on your server
/templates/deals_plazza/css/template.cs.php
if not, please make it writeable first.
Or it would be better also to check your /templates/deals_plazza/css/ folder if it's already has 755 (writeable) permission code then see if that helps.
13 years 9 months ago #2 by erwinschro
I made the file writeable in the my godaddy permissions. What is the next step?
13 years 9 months ago #3 by tony Smith
Here is my css folder, is there suppose to be a 755 file?
13 years 9 months ago #4 by tony Smith
So sorry but please make sure all css files should be 644 and CSS folder should be 755
13 years 9 months ago #5 by erwinschro
Im sorry, I will need some more direction for this issue. Do I rename them all to 644 or delete the others. Im a little confused and new the html side.
13 years 9 months ago #6 by tony Smith
