How to add a module into Module in Modal
- Posted by Scott (24) Offline
I just purchased extension and The documentation at first glanced looked promising but there is no information on how to add Joomla Module to Module in Modal.
Please advise as to how this is done.
Scott
8 years 6 months ago #1
by Scott
Scott
found itr but thi si snot what I was expecting this is popup for a template module position NOT a custom module..
is there a way to assign an actual module to this Modal? for example a contact form
8 years 6 months ago #2
by Scott
Hi, yes, as the name suggest, with the module you can place any module inside a modal / popup. For a contact form, you can install any contact form module (you can get one at extensions.joomla.org/extensions/contact...dback/contact-forms/ ) then publish it to position you have set the module in modal.
8 years 6 months ago #3
I already use JSN Uniforms but your plugin Module in Modal does not recognize modules only template module positions which is mis-leading I am requesting a refund.
8 years 6 months ago #4
by Scott
Of course it recognizes the module, via module position, you will need a module position when publish a module, right?I already use JSN Uniforms but your plugin Module in Modal does not recognize modules only template module positions which is mis-leading I am requesting a refund.
If you're worry that your module position have a lot of modules published on it, then you can type the custom module position that your template doesn't have, to make sure only one module is loaded inside the module in modal's module.
Please have a look on this video to see what I mean : www.dropbox.com/s%2Fbsmlra0k7eszm4o%2Fmodallin.mp4%3Fdl%3D0
or
bit.ly/2ovt7hE
I tried this again and it make no sense I am have to assign template module position...this make no sense Please see attached images
Image A shows user: only a few but non of the 12 custom modules I created.
Image B shows template postions
This is clearly not doing what it is advertised to do,
Your documentation needs a lot of work and maybe rename your plugin to Template Module Positions in Modal
I really should not need to spends 6 hours to try and get this extension to work when it's clearly not designed to function the way iit is advertised.
8 years 6 months ago #6
by Scott
