How to make banner responsive
- Posted by Procoma (10) Offline
Have a look at gordonsbay.travel. There are two banners in on the homepage and all works fine except when I switch to responsive. The picture in the banner does not resize and I cannot find the setting for that.
6 years 11 months ago #1
by Procoma
Hi, I have visited your website and unable to spot the two banners you mentioned. Can you point me to it?
6 years 11 months ago #2
Hi, go to gordonsbay.travel homepage, scroll down and after "Explore Gordon's Bay" you will find "Sponsored Ads". These are the banners and if you resize the screen smaller you will see that that the pictures do not resize correctly.
See also attached pictures.
6 years 11 months ago #3
by Procoma
Can you try to publish the module in other position? Because when I try to inspect that position, it's indeed wrapper for that position divided into 2 columns for smartphone viewport
https://www.dropbox.com/s%2F8wuj97c64z4t2ra%2Fwgt0y.jpg?raw=1
6 years 11 months ago #4
It is now in section-1 which is just below the slider at the top. Section-1 is one column.
If I resize smaller, the images still does not resize correctly.
6 years 11 months ago #5
by Procoma
Can you provide a temporary access to your web site so I can check it by myself? If it's possible you can provide it in the 'Your Site Details' below. Only you and support agent who will be able to see it.
6 years 11 months ago #6
