Minifrontpage white page
- Posted by Fritz (7) Offline
I have installed Minifrontpage version 3.1.0 and it works just fine on all but one page, thefireplace.com.au/heating/biofuel-fires/icon-fires which, when Minifrontpage is activated, goes blank and has no source code.
This suggested to me an extension conflict and so I created a "bare bones" page which contains only an article and no other extensions. This page was not a duplicate of another with extensions switched off but was built as a new page. The URL of this page is thefireplace.com.au/heating/biofuel-fires/icon-fires-3 and is accessible only to Super Users. I also created a new Minifrontpage module for this page. This page also goes blank with no source code when the Minifrontpage module is activated.
Given that Minifrontpage works on all other pages it cannot be a server problem nor a Joomla version (3.9.10) problem.
Server information is at thefireplace.com.au/info.php
Can you assist please?
5 years 6 months ago #1
by Fritz
Hi, this is usually because one of your article has an incorrect image url (image cannot found). It will be fixed in the next update. But in the mean time you can try to check the article that published on that page.
5 years 6 months ago #2
These are the only images appearing in the " bare bones" page refered to above:-
thefireplace.com.au/favicon.ico
thefireplace.com.au/images/front_page/AHHA_logo_black.png
thefireplace.com.au/media/com_favicon/icons/1/favicon.ico
thefireplace.com.au/templates/g5_hadron/...ogo/preset1/logo.png
/rgb(255,%20255,%20255 appears odd and appears on all pages but for the home page and without any problems. Using Developer Tools it shows as a missing image and it also appears as a different colour on the contact page {/rgb(0,%20136,%20204). All of the pages are functioning correctly but for thefireplace.com.au/heating/biofuel-fires/icon-fires-3. Therefore it cannot be the cause of the problem. /rgb(255,%20255,%20255 does not appear in the source code.
Each time I tested the pages I cleared the Joomla cache, the expired cache and the browser cache.
I have replaced the page content with a single letter so there is no article to check.
Cheers
5 years 6 months ago #3
by Fritz
Cheers
Hey fritzula,
I was entering to your administrator page and trying to change the Error Reporting to Development in the Global Configuration to find out what exactly error message returned on the page thefireplace.com.au/heating/biofuel-fires/icon-fires-3 ,
But after I saved the configuration, your website suddenly become inaccessible and returned errorI'm trying to return back the Error reporting to Default by editing the configuration.php file but the credentials you provide above doesn't let me in to ftp. So if you can, please open the file configuration.php, change back the lineinto
5 years 6 months ago #6
Deprecated: Array and string offset access syntax with curly braces is deprecated in /home/thefirep/public_html/libraries/joomla/database/driver.php on line 1956public $error_reporting = 'development';public $error_reporting = 'default';Please Log in or Create an account to join the conversation.
