minifrontpage does not generate thumb
- Posted by nome (11) Offline
hello,
on my site Minifrontpage does not generate any thumb. Olny generate thumb of a default image (after deleting mod_minifrontpage folder and reinstall the plugin)
i use joomla 4.1.5, jce editor, and installed Version 4.0.0 - 03-07-22
4 years 3 months ago #1
by nome
On this page : www.infoparigi.it/staging/disneyland-par...per-disneyland-paris
Can you try to change the path of image url from :to
and then delete all existing images under folder /images/thumbnails/mod_minifrontpage so the module can re-generate the thumbnail
https://www.dropbox.com/s%2F3lnya6qgzo8n42f%2Fmonosnap%25202022-07-06%252005-46-07.png?raw=1
4 years 3 months ago #4
https://www.infoparigi.it/staging/images/disneyland/p_topolino43.png/images/disneyland/p_topolino43.pngand then delete all existing images under folder /images/thumbnails/mod_minifrontpage so the module can re-generate the thumbnail
Hi have you managed to solve the issue? Can you share temporary access to your website so I can have a look on it directly? If you can, you can share it in the Your Site Details tab below. Only you and support staffs who are able to see it.
4 years 3 months ago #5
Hello, thanks for help.
I've tryed to modify the path of the image, but jce transform the urs in a complete url path.
I' ve also tryed with a .jpeg image.
Anyway I add credentials to let you an access...
thanks
4 years 3 months ago #6
by nome
thanks
