Whatsapp premium bool error
- Posted by magdalena (6) Offline
Dear Templateplazza:
In my site when I try to publish module Whatsapp premium It send error
0 Call to a member function modify() on bool
What can it be ? It was working fine
Many thanks for Issue
Magdalena M.
4 years 1 month ago #1
by magdalena
Magdalena M.
Dear Templazza.
Hi! when you make change other components get trouble I don´t know why, but now everything is fixed.
Now making new test Module Whatsapp premium dessapear I make a Item Menu where Module must be shown
In working with Modules Anywhere - and Advanced Modules of Regular labs for selecting the item menu where Whatsapp premium must be show. But it doesn´t..
datobarrio.cl/inicio/index.php/prob (I.m working in design)
Please tell me if you make changes, for knowing if conflict what can be..
Dear a question, how many modules can be made ?
Many thanks !!
Wait your Awnser Many thanks !!
Magdalena Murillo =)
4 years 1 month ago #3
by magdalena
Many thanks !!
Hi Magdalena,
https://www.dropbox.com/s%2Fdcqvekcfeyxaxih%2Fyour%2520joomla%2520site%2520-%2520prueba%2520%25202022-09-23%252006-53-30.png?raw=1
4 years 1 month ago #4
I was fixing the issue before I replied to your initial post abovewhen you make change other components get trouble I don´t know why, but now everything is fixed.
I tried to create a new module whatsapp instance and it looks like it worked. The whatsapp module is displayed, but the whatsapp function seems not working because you have another error on that page that prevent the module to work. Please see the screenshotIn working with Modules Anywhere - and Advanced Modules of Regular labs for selecting the item menu where Whatsapp premium must be show. But it doesn´t..
Did you mean, how many modules can be create in a website? You can create as many as module you want but please make sure only one module published in one page.Dear a question, how many modules can be made ?
Thanks now it works, a question I need it to work in Module Asignement URL
datobarrio.cl/inicio/index.php/automotri...otors-automotora-311
With this method Module Whatsapp premium is shown but It don´t send.
Many thanks for awnser
Magdalena Murillo B
4 years 1 month ago #5
by magdalena
Magdalena Murillo B
Yes it's because you have error on your template / website as I mentioned before. https://www.dropbox.com/s%2Fkkmrmd1crrb3z47%2Fyour%2520joomla%2520site%2520-%2520lahrbrownemotors%2520automotora%25202022-09-23%252011-06-09.png?raw=1
Can you check what caused that error?
4 years 1 month ago #6
