MiniFrontPagePro - No thumbnails using Dropeditor/Dropics
- Posted by Jonathan Day (5) Offline
I recently purchased MiniFrontPagePro but seem to be experiencing a conflict when using my preferred text editor DropEditor with Droppics media manager.
www.joomunited.com/joomla-demo/dropedito...-editor-presentation
When I create an article and insert an image using this editor, the thumbnail does not display
www.saintclares.co.uk/index.php
if I use an alternative editor such as JCE, it work fine but I would really like to use this Dropeditor as it is easier for the users I work with.
I hope you can help,
Jonathan
3 years 3 weeks ago #1
by Jonathan Day
Jonathan
Hi,it looks like DropEditor is adding additional code within the <img> tag when inserting an image. Let me check on it
3 years 3 weeks ago #2
Hi can you share temporary access to your website so I can try the fix? If you can, you can share the credentials using the confidential icon
3 years 3 weeks ago #3
I don't have permission to install the module. I've uploaded the fix here; you can try to install it and let me know whether it's working or not.
3 years 3 weeks ago #5
This message contains confidential information
Thanks for your amazingly fast response to this issue. You mention that you have applied a fix to the module but I don't see it attached to the message. Is there somewhere else I should be looking?
Kind regards,
Jonathan
3 years 3 weeks ago #6
by Jonathan Day
Kind regards,
Jonathan
