Floating Buttons load problem after update
- Posted by Arman Mohseni (6) Offline
I've been using Floating Buttons on my website for a while now. Today, I updated the module to version 2.0.0, and it stopped working. The error I see in the console is related to jqueryFab.
I'm using the Helix Ultimate template and Joomla 4.4.1.
I've tried uninstalling and reinstalling the module, but it didn't fix the issue.
I would appreciate it if you could guide me on what I can do next.
2 years 11 months ago #1
by Arman Mohseni
The jquery is no longer needed in the version 2.0.0 so it’s probably your Joomla Cache. Try to clear your joomla cache and also your browser caches
2 years 11 months ago #2
Thank you for your response.
I cleared the cache and even deactivated it to test, but the error still persisted. I've also tested it again with a different browser, yet I'm encountering the same error.
2 years 11 months ago #3
by Arman Mohseni
Could you please provide me with your website URL so that I can check it?
2 years 11 months ago #4
