MINIFRONTPAGE PRO J4 urls to be created as they used to in J3..is it possible?
- Posted by Petros Alexandrou (10) Offline
After the upgrade to Joomla 4 all the urls from Minifrontpage are created with a different method and therefor i have broken links of all the old articles displayed with Minifrontpage. Is there any solution to this issue?
2 years 5 months ago #1
- Posted by TemplatePlazza (5456) Offline
Hi, have you tried clearing your Joomla cache? Go to Administrator > System > Maintenance > Clear Cache. Could you please provide the website url where the issue exist?
2 years 5 months ago #2
I did empty the cache
J4 sample
www.magnumserve.com/en/publications?view...to-covid-19&catid=12
J3 sample (error 404)
www.magnumserve.com/en/publications/12-p...response-to-covid-19
2 years 5 months ago - 2 years 5 months ago #3
J4 sample
Last edit: 2 years 5 months ago by Petros Alexandrou.
Can you try reinstalling the module and see if it fixes the issue?
2 years 5 months ago #4
I did it and there is no change - the problem is that its a 10 years website with a lot of articles created with the old urls
2 years 5 months ago #5
Is this the situation? forum.joomla.org/viewtopic.php?t=996848
Re: J4 Component URL not SEF
<<To summerize all what I need to create a routing in J4 (with same behavior that J3) >>In the bottom the solution
2 years 5 months ago #6
