Simple Float Button
Hi, I have installed the module, I wonder where should I publish the module. any specific location?
Thank you.
2 years 8 months ago #1 by ahyong
You can place in the debug position
2 years 8 months ago #2 by TemplatePlazza
Please tell me how to make the menu list permanently open.
2 years 7 months ago #3 by driverXP
templateplazza.com/forums/technical-supp...ns-always-open#16202
2 years 7 months ago #4 by TemplatePlazza
Thank you very much for your reply.
Please tell me how to correctly add the code of the pop-up button of the feedback form to the URL field:
<a data-id="109" class="wjcallback-link" href="#" data-ym-aimid="popuptest">Order a call</a>
2 years 7 months ago #5 by driverXP
Hi, sorry, but the URL should be a direct URL only. If you are familiar with PHP, you can achieve that through template override by changing the way the URL is called.
2 years 7 months ago #6 by TemplatePlazza
