multiiple templates
Helo,
i want to sent the launchtime as front end of public home template,
and in my administrator back end where i do the magic, in the site view button, i want to see its result of my work and not the launchtime, how to do so ?
picture attached,..
thanks :D
13 years 8 months ago #1 by joseph gunawan
Well ... you can assign LaunchTime template only to your Home/default menu item and assign another template (which is used to display your works) to other menu item that point to your work page.
that will do the trick.
13 years 8 months ago #2 by erwinschro
? how can i access to other template while LT is the home default,..
as if i want to see the result of my editing the viewsite directs to LT,
i want to see the home of another template if i click view site
please advice
13 years 8 months ago #3 by joseph gunawan
how to direct viewsite from backend to other template not the launchtime ?
13 years 8 months ago #4 by joseph gunawan
Ooh I misunderstood what you're intention ...
I really don't have an idea on that thing. IF you're on the development site in your local pc, then you can switch to other template than LT first just to see your work page.
13 years 8 months ago #5 by erwinschro
Yes you can put LT online BUT you CAN't click the View Site button in the backend and hoping another template is loaded in the frontpage (your Home menu item) as that View site link button is coded to go to your site home page meanwhile this LT template has been assigned to your default menu item (Your 'home' page).
Try to ask this in the Joomla forum and let me know if there's someone have another opinion, will you?
13 years 8 months ago #6 by erwinschro
