Responsive Banner Slider & JQuery
- Posted by Daniel (6) Offline
Hi there,
I just purchased the Slider, installed it, added some pix.... and then nothing happened.
I guess it is a jQuery issue. It says somewhere Jquery not defined...
This is the site, could you have a look ?
Thank you very much,
best
Daniel
13 years 4 months ago #1
by Daniel
best
Daniel
Hmm, it looks like your template does have a built-in javascript compressor so it compiles all of javascripts into one file (http://www.lo****-eu.com/cache/gk/xxxxxxxxxxxxxxxxxxxxxxxxx.js.php), but strangely I see not all of responsive banner slider javascript files included in the compressed file.
Can you try to disable the script compressor function to see what is exactly happening?
13 years 4 months ago #2
by andy
Oh, thank you for your quick reply. That is really cool.
Indeed, there is a java compression function which I disabled in my template.
But still no go. The slider does not function yet.
What should I do next ?
13 years 4 months ago #3
by Daniel
Umm when I tried to visit your website now it says
13 years 4 months ago #4
by andy
did you put it offline?New site is being installed
Please check back again soon
Yes, sorry, I reinstalled a backup and reinstalled the plugin again - but to no avail.
Would you like to have a look ?
13 years 4 months ago #5
by Daniel
Ok it's now working good.
But can you please disable again the compressor function, so I can see why the module javascripts not included in the output file
13 years 4 months ago #6
by andy
