Responsive banner does not work
Re Responsive Banner. Have just purchased this and it does not work. It will not transition, it just remains on one banner. Have gone through all settings and cannot see a reason it should not work.
13 years 6 days ago #1 by johnname
I don;t see you publish the module now, have you unpublish it?
can you re-publish it so we can take a look if you still want to?
13 years 6 days ago #2 by erwinschro
Yes I will re publish it and leave it. tonight and tomorrow
13 years 6 days ago #3 by johnname
Also Nivo does not appear at all and Sequence is just black so adapter slider is the only one that at least put one banner up!
13 years 6 days ago #4 by johnname
Is there an option to de-activate jQuery library from your mod_swmenu module? as there's jQuery library has been load by the template and now there's 2 jquery library loaded which I suspect conflicted on each other and see if that helps
13 years 5 days ago #5 by erwinschro
No I cannot de activate jQuery from swmenu. But if I turn it off it does work. Obviously I need the menu turned on, so wht do you suggest now?
13 years 5 days ago #6 by johnname
