Responsive Banner Slider not switching images
I have the banner installed successfully. When i select the sequence slider type for some reason the image wont change from the first one automatically, if i change it manually the it'll switch back fine, its just the initial change. i cant figure it out am i being dumb.
12 years 8 months ago #1 by Chris Morden
Hi, Can you share your website URL so I can take a look?
12 years 8 months ago #2 by TemplatePlazza
I'm afraid i cant i'm designing a new site for a company and its only locally created at the mo :/ sorry
12 years 8 months ago #3 by Chris Morden
Hmm, it's difficult to track/debug the problem without seeing it directly on the browser.
Can you check whether your website loads multiple jquery libs or not?
12 years 8 months ago #4 by TemplatePlazza
I don't believe so. From what i can tell its literally style 2 on the sequence styler, every other style of slider works fine.
12 years 8 months ago #5 by Chris Morden
- What joomla version you're working on?
- How many banners you're currently added?
- What template did you use?
- How about to swicth to default template (protostar). does the problem exist?
- Is there any other module published on the same page? Can you try to unpublish all other modules on that page to see whether the problem persist or not
12 years 8 months ago #6 by TemplatePlazza
