Responsive banner pre-fetch
- Posted by Ian Blackie (7) Offline
The banners are being displayed and are rotating but prior to the next banner i see a preview of the next banner in the top left corner of the current banner. It is very small but certainly unwanted. Joomla 3.1,
www.usstripbars.com
12 years 8 months ago #1
by Ian Blackie
www.usstripbars.com
Hmm, strange. Can you temporarily switch the template to default one (protostar) to check whether this is a template problem or something else
12 years 8 months ago #2
Too risky, it a live site. I have noticed that the tiny pre fetch is actually doing the transitions and then when it is complete the banner refreshes and shows the full size. I'm using Nivo right now, when i select Adaptor or Sequence the banner only appears as a thin sliver.
12 years 8 months ago #3
by Ian Blackie
Hmm, you can create a new (hidden) menu item, set protostar template on that menu and set the module to be published in there.Too risky, it a live site
I have put it on a hidden menu (registered) using protostar template and it works fine. Can you point me in the right direction so i can figure out what to focus on when i contact the template developer please. Using a joomlart template with T3, bootstrap & K2.
Thanks.
12 years 8 months ago #5
by Ian Blackie
Thanks.
Hi, Sorry for delay in responding.
It looks like it because your template css force the max-width value = 100% for all of <img> tag.
Can you try to add this css in the very end of your css file :
12 years 8 months ago #6
.nivoSlider img {
max-width: none!important;
