Carousel Banner - doesn't show
- Posted by Hooman (10) Offline
Installed the module and created some sample banners but the module doesn't show anything. I've tried different jquery settings in the module but it didn't help.
Is it possible for you to have a look at it?
Hooman
12 years 4 months ago #1
by Hooman
Hooman
Hi Hooman, sorry for delay in responding. I've visited your website but I didn't see any carousel banner installed. Can you point to the page where the module exist?
Thank you
12 years 4 months ago #2
Thank you
Hi there
That's exactly the problem. I've installed the module and I've selected "Flexisel" in the layout settings but it doesn't show anything.
I've got the module enabled on this page: stkildamelbourne.com.au/contact/st-kilda...on-mission-statement
If it works we should see it under the top menu but for some strange reason it's not working. In the module settings if I change the layout to "default" then instead of having the slider it will show the banners under each other.
12 years 4 months ago #3
by Hooman
Hmm, I think it's a multiple jquery problem. When I checked your html source I found jquery is loaded more than once. Please see
www.dropbox.com/s/1ikqxtaax7y77m2/vie03.jpg
12 years 4 months ago #4
That was what I thought at first, but even changing the "Load jquery" to "No" didn't fix the problem.
12 years 4 months ago #5
by Hooman
Yes disableing the load jquery won't help because carousel javascript is loaded before your built-in jquery. Do you use any extension that changing the <head> items direction or moving all javascript to the bottom of page?
12 years 4 months ago #6
