LatestNews+
- Posted by Antar (8) Offline
Could I suggest adding Unicode support to the plugin? Authors? Intro text right now cutting off at half-byte of character (site on Russian, utf-
and mysteriuos and squares characters appear. And it looks ugly.
As far as I remember this is old problem of English scripts with Russian encoding. Periodically, when I install new script I had to solve this problem. There should be one function added somewhere I don't know where. Or decode, or encode.. =-/
14 years 1 week ago #1
by Antar
- Posted by ronysyz (191) Offline
Hello Antar,
Thank you for using this module
mmm... it's the old problem that we have fixed it
do you use the latest version?
14 years 1 week ago #2
by ronysyz
I see only one version - the one that can be downloaded by clicking Download button there: www.templateplazza.com/products/code/joo...ocument/13-latesnews
It's 2.0.2
14 years 1 week ago #3
by Antar
It's 2.0.2
What about if you try with this trick
please go to "modules/mod_latestnewsplusdate/", open file helper.php and change all substr to mb_substr
Please make sure that there are 3 substr that you need to change to mb_substr
Please let me know what happen after you try it
Good Luck
14 years 1 week ago #4
by ronysyz
Good Luck
I don't see any. They are all in helper.php. But replacement didn't give any effect. Everything remained the same.
14 years 1 week ago #5
by Antar
what about if you try to test with minifrontpage module, is it same?
14 years 1 week ago #6
by ronysyz
