E-mail from Contactmap not being send?
- Posted by Ton van der Helm (67) Offline
Hello, on my test page I'm using Contactmap and in the module I have tried two of my e-mail adresses as recipient. When I send a mail through the contactform the mail doesn't arrive. What can I do about this? Thanks!
10 years 3 months ago #1
by Ton van der Helm
- Posted by TemplatePlazza (5456) Offline
Hi did you receive any emails from your server? For example registration email when a new user is registered, or email from joomla com_contact? The module uses the jooma sendmail function so if your server sendmail working properly then it should be working properly too.
Or maybe checking your spam folder?
10 years 3 months ago #2
I've send a test e-mail from the backend and I received that one. I'm using the SMTP option. Is it oké if I give you access to the backend?
10 years 3 months ago #3
by Ton van der Helm
Yes. You can enter the details using the "You Site Details" tab below. Only support team who are able to see that.
10 years 3 months ago #4
Hmm strange, it looks like the form is not processed. Clicking the button always forward user to 94.228.131.44/~bruhenuit/index.php?optio...icle&id=1&Itemid=101 not processing the form. Can you try to move the module to other position and let me know the result?
10 years 3 months ago #6
