Joomla 4.3 - Frontend not loading Carousel Banners - Require Banner Helper?
- Posted by Kae Wan (11) Offline
Hi,I just upgraded from Joomla 3.10 to 4.3 (latest update package). Everything seems to be working fine on the backend. However, the frontend does not seem to be loading the Carousel Banners modules.Here is issue below.
mod_fcgid: stderr: PHP Warning: require_once(/home/website/public_html/components/com_banners/helpers/banner.php): Failed to open stream: No such file or directory in /home/website/public_html/modules/mod_carousel_banner/tmpl/flexisel.php on line 15I have checked the actual file its trying to load and it looks it does not exist anymore. Does the Carousel Banner plugin need to be updated for Joomla 4.3?Thanks,
Kae
3 years 6 months ago #1
by Kae Wan
Kae
Hi, what module version do you use? Flexisel is no longer used since the version 3.xx
3 years 6 months ago #2
It was Carousel Banner version 3 before the upgrade.
Once I upgraded, I installed Carousel Banner version 4. Does this upgrade the plugin? Or do I need uninstall and reinstall?
Although, I don't want completely uninstall the plugin because it will delete the existing Carousel Banner modules...
3 years 6 months ago #3
by Kae Wan
I meant what Carousel Banner version do you have
Its version 3.2.1.
I am just wondering if its because of the different Carousel Banner versions files crossing. i.e. one for Joomla 3 and one for Joomla 4. I did not uninstall Carousel Banner (J3 version) before installing Carousel Banner (J4 version) as I did not want to the existing Carousel Banner modules deleted.
3 years 6 months ago #6
by Kae Wan
