Where is Exclude category id(s) option
- Posted by David (15) Offline
I just purchased Related Items Extended, then i download and install it, but i can not found the "Exclude category id(s) option", where is it?
My joomla is 3.2.3
Thank you!
David
12 years 2 months ago #1
by David
My joomla is 3.2.3
Thank you!
David
Hi davidyv,
We're sorry but Related Item extended doesn't have that option
12 years 2 months ago #2
Your Changelog:(www.templateplazza.com/download/view_doc...lated-items-extended)
Version 1.1.5 - 7/10/2013
+ Added : Exclude category id(s) option
I already purchased it at 2013/10/31, today, I again buy it because this function, so, could you please help me to check it out?
Thanks!
David
12 years 2 months ago #3
by David
Thanks!
David
Hi david,
Can you try this attached version below and let me know whether it's working good or not?
12 years 2 months ago #4
It can not work and report the error messages:
Error: 1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND (a.publish_up = '0000-00-00 00:00:00' OR a.publish_up <= '2014-08-12 06:32' at line 11 SQL=SELECT a.id,a.title,a.introtext,a.images,a.metakey,DATE_FORMAT(a.created, "%Y-%m-%d") as created,a.catid,cc.title as category_title,cc.access AS cat_access,cc.published AS cat_state, CASE WHEN CHAR_LENGTH(a.alias) THEN CONCAT_WS(':', a.id, a.alias) ELSE a.id END as slug, CASE WHEN CHAR_LENGTH(cc.alias) THEN CONCAT_WS(':', cc.id, cc.alias) ELSE cc.id END as catslug,u.name AS author,contact.id as contactid FROM mqi6r_content AS a LEFT JOIN mqi6r_content_frontpage AS f ON f.content_id = a.id LEFT JOIN mqi6r_categories AS cc ON cc.id = a.catid LEFT JOIN mqi6r_users AS u on u.id = a.created_by LEFT JOIN ( SELECT contact.user_id, MAX(contact.id) AS id, contact.language FROM mqi6r_contact_details AS contact WHERE contact.published = 1 GROUP BY contact.user_id, contact.language) AS contact ON contact.user_id = a.created_by WHERE a.id != 34 AND a.state = 1 AND a.access IN (1,1) AND (CONCAT(",", REPLACE(a.metakey, ", ", ","), ",") LIKE "%Analyzer Filters%" OR CONCAT(",", REPLACE(a.metakey, ", ", ","), ",") LIKE "%test2%") AND cc.id not in () AND (a.publish_up = '0000-00-00 00:00:00' OR a.publish_up <= '2014-08-12 06:32:16') AND (a.publish_down = '0000-00-00 00:00:00' OR a.publish_down >= '2014-08-12 06:32:16') AND ( (TO_DAYS('2014-08-12') - TO_DAYS(a.created) ) <= '1200') AND a.language in ('en-GB','*') ORDER BY a.created DESC LIMIT 0, 5
12 years 2 months ago #5
by David
