fatal error in Minik2
- Posted by rnkosi (1) Offline
I installed MiniK2 but when I activate it my whole site crashes and this error pops up; Fatal error: Class 'K2Model' not found in
C:\wamp\www\Test\modules\mod_minik2\helper.php on line 262. Help!
13 years 11 months ago #1
by rnkosi
- Posted by ronysyz (191) Offline
Hello rnkosi,
Welcome to TP,
Do you use the latest version of K2?
13 years 11 months ago #2
by ronysyz
Welcome to TP,
- Posted by OLIVER STANTON (3) Offline
i have this problem as well even with the latest k2 version
13 years 11 months ago #3
by OLIVER STANTON
Hello Grippatank
Could you tell us your Joomla version? Is it Joomla 3.0?
13 years 11 months ago #4
- Posted by blackbee (1) Offline
Same problem here, using the last version (1.2.1). I worked with 1.0 on a website before and had no problem. Guess it's a problem with the new version. I'm working with the 1.0 again. Great extension by the way.
13 years 11 months ago #5
by blackbee
Blackbee thanks for your kind words...
As i said before
13 years 11 months ago #6
As i said before
